B7800 3 pt. Upper arm
   / B7800 3 pt. Upper arm #1
N1ST
Enfield, CT
Kubota B7800
Geesh, I sprang for the expensive $40 Indian made TSC upper arm, get it home, greased it up good and it doesn't fit into the tractor side bracket. Is it too wide or is the tractor too narrow? Does the $20 Indian made one fit? All I have is a dremel for grinding, and the cat 1 hole pivot thingy looks pretty darn thick.
   / B7800 3 pt. Upper arm #2
All the parts for my 7800 came with the tractor, including the upper arm and a tow hitch! Did you not get all the parts or is this a specialty item?
   / B7800 3 pt. Upper arm #3
IT is probably the center hub that is to wide. We've ground them down before to fit.
I have pat's quick connects so I need a longer upper arm especially with a rotary mower.
Yup. How much of a job would it be to grind down with a little dremmel stone?
   / B7800 3 pt. Upper arm #6
I use one on my B7800 when I'm pulling my disc as the extra length gives me more ground engagement on the rear discs. I had to grind it to fit and I used a 4" disc grinder. I think it would take a lot to remove the metal with a dremel tool. A cheap grinder from Harbor Freight, for example, and a single disc would do it for you.:)
   / B7800 3 pt. Upper arm #7
I should have mentioned that I bought a standard length and a longer one and I had to grind both.
Barney
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2018 PJ  30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
377811 (A48836)
377811 (A48836)
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
