B7800 3 pt. Upper arm
   / B7800 3 pt. Upper arm #1
N1ST
Enfield, CT
Kubota B7800
Geesh, I sprang for the expensive $40 Indian made TSC upper arm, get it home, greased it up good and it doesn't fit into the tractor side bracket. Is it too wide or is the tractor too narrow? Does the $20 Indian made one fit? All I have is a dremel for grinding, and the cat 1 hole pivot thingy looks pretty darn thick.
   / B7800 3 pt. Upper arm #2
All the parts for my 7800 came with the tractor, including the upper arm and a tow hitch! Did you not get all the parts or is this a specialty item?
   / B7800 3 pt. Upper arm #3
IT is probably the center hub that is to wide. We've ground them down before to fit.
I have pat's quick connects so I need a longer upper arm especially with a rotary mower.
Yup. How much of a job would it be to grind down with a little dremmel stone?
   / B7800 3 pt. Upper arm #6
I use one on my B7800 when I'm pulling my disc as the extra length gives me more ground engagement on the rear discs. I had to grind it to fit and I used a 4" disc grinder. I think it would take a lot to remove the metal with a dremel tool. A cheap grinder from Harbor Freight, for example, and a single disc would do it for you.:)
   / B7800 3 pt. Upper arm #7
I should have mentioned that I bought a standard length and a longer one and I had to grind both.
Barney
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
