B7800 3 PT hitch lowering speed knob, PTO
   / B7800 3 PT hitch lowering speed knob, PTO #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
B7800 3 PT knob,should this be in the lock position when starting and also not in use,when I do have an attachment hooked up should the knob be in the locked position when starting? also mid and rear PTO to off position unless in use. This is my first tractor any other advice is welcomed.
   / B7800 3 PT hitch lowering speed knob, PTO #2
The Hydraulic speed control can be left open, I rarely shut mine off except to exercise it. The PTO mid /rear should be shut off before shutting of the tractor and/or starting the tractor. Do you have a ROPS (roll bar)? If so use your seat belt. Do you have a FEL (front end loader)? If so keep it low on the hills a FEL can make you tip over easy on a slope if you raise it up. I would encourage you to read the owners manual for your tractor as well. Do a search on tractor safety a tractor is a good way to get hurt but if you understand the dangers they are safe to use and enjoyable at that.
   / B7800 3 PT hitch lowering speed knob, PTO #3
Besides reading the manual about safety, if you go to the home page of Tractor by Net and click on "discussions" tab, and scroll down, you will find one on tractor safety. I have browsed through this several times and always find something to add to my list of mental safety items.
Thanks for the heads up on the safety tips. I am most definitely NOT a risk taker.
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2003 PETERBILT 379 (A50854)
2003 PETERBILT 379...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
