B7800 3 PT hitch lowering speed knob, PTO
   / B7800 3 PT hitch lowering speed knob, PTO #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
B7800 3 PT knob,should this be in the lock position when starting and also not in use,when I do have an attachment hooked up should the knob be in the locked position when starting? also mid and rear PTO to off position unless in use. This is my first tractor any other advice is welcomed.
   / B7800 3 PT hitch lowering speed knob, PTO #2
The Hydraulic speed control can be left open, I rarely shut mine off except to exercise it. The PTO mid /rear should be shut off before shutting of the tractor and/or starting the tractor. Do you have a ROPS (roll bar)? If so use your seat belt. Do you have a FEL (front end loader)? If so keep it low on the hills a FEL can make you tip over easy on a slope if you raise it up. I would encourage you to read the owners manual for your tractor as well. Do a search on tractor safety a tractor is a good way to get hurt but if you understand the dangers they are safe to use and enjoyable at that.
   / B7800 3 PT hitch lowering speed knob, PTO #3
Besides reading the manual about safety, if you go to the home page of Tractor by Net and click on "discussions" tab, and scroll down, you will find one on tractor safety. I have browsed through this several times and always find something to add to my list of mental safety items.
Thanks for the heads up on the safety tips. I am most definitely NOT a risk taker.
2016 KENWORTH T660 SLEEPER TRUCK (A50854)
2016 KENWORTH T660...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
2024 Chevrolet Silverado Pickup Truck Bed (A49461)
2024 Chevrolet...
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
