Mowing B7610 mower deck adjustment
/ B7610 mower deck adjustment #1
hagman
Central, IL
B7610 Kubota
Hello Fellow Kubota owners,
After buying a used B7610 with the 54" mmm I am now trying to figure out how to adjust the mower drck properly. It was never done by the previous owner and when raising the deck up the front wheels still make contact with the ground. I know that the mowing heigth is set by the wheel adjustments but I'm trying to find out the overall heigth deck adjustment. The manual is little or no help. Anyone out there with a B7610 that can give me some advice? Thanks for any replies I get.
Hagman
/ B7610 mower deck adjustment #2
Hello Hagman - I have the 60" but will throw my .02 in because I had a similar issue when I removed the deck and reinstalled the first time. Basically, I did not hook the front hanger bracketry to the deck mounting point correctly. I simply hooked the end of the front hanger bracket into the deck catch points. Then I noticed when I raised the 3-pt all the way up, the deck front was angled down and clearly did not raise as high or as level as it did before I removed it. It also seemed alarmingly close to the rear tires. After a quick peek in the manual, I noticed that the catch points on the front of the mower deck hooked onto the cross pin of the 'U' adjusters on the front hanger bracket. Just flip the hanger bracketry ends up, then slip the 'U' adjuster pins into the deck catches. Hope that made sense, sorry no pic handy. If your deck is connected properly and you are simply looking for guidance on which hole pin adjustment to use for each anti-scalp wheel or how to level the deck correctly, I'm sure someone with the same deck will chime in!
2017 Subaru Forrester (A62613)
2017 Subaru...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
8ft Fork Extensions (A61572)
8ft Fork...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A61572)
2025 Mower King...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2015 Ford Escape 4WD SUV (A61574)
2015 Ford Escape...
