B7610 Hour meter on tach -- is it RPM based, or time based?
   / B7610 Hour meter on tach -- is it RPM based, or time based? #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
I've only had my B7610 for a short time, but today, I noticed that I think the hour meter (which is in the tach) is based on RPM (which makes sense for maintenance), instead of clock time. I came from a B7100, which had no tach, so the hour meter was a basic hobbs-styled that just measured time.
I had 132.6 when I start working this morning at around 9:30am, and at noon, have just 133.5. I wasn't running it the whole two hours, but I'm pretty sure I was running it for a good bit more than 1 hour. I was mostly pulling my landscape rake, so I was running at 1500 RPM (PTO power is 2600 RPM).
Thanks,
Jay
   / B7610 Hour meter on tach -- is it RPM based, or time based? #2
My bx24 is time based. And usually when I'm on my tractor, I tend to lose track of time which can equate to either more or less time than I think it is :D.
   / B7610 Hour meter on tach -- is it RPM based, or time based? #3
My B7800 is RPM based (the tachometer/hour meter runs from the engine via a flexible speedometer-type cable). I suspect yours is too.
   / B7610 Hour meter on tach -- is it RPM based, or time based? #4
very good to know, thanks for this info!
   / B7610 Hour meter on tach -- is it RPM based, or time based? #5
This brings up a good point. I may log and time hack some operations to check that. I have actually left it running when I went to lunch.
2016 ISUZU NPRXD 14' BOX TRUCK (A60430)
2016 ISUZU NPRXD...
VOLVO A25G OFF ROAD DUMP TRUCK (A60429)
VOLVO A25G OFF...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
John Deere 4520 (A60462)
John Deere 4520...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
