B7500 HST power steering and and 3 point lift problems in high temp.
   / B7500 HST power steering and and 3 point lift problems in high temp. #51
I have a B2400HSD. My tractor does not appear to be plumbed as shown with the return line going directly into the main line. I could be mistaken but this does not seem to apply to my problem. Again, since I've been using AMSOIL hydraulic fluid, with the exception of the first 2 or 3 mowing jobs, I've had zero problems. In the past I used UDT, Super UDT, Bobcat fluid, and TSC fluid. When I was using any of those fluids, after an hour of hard mowing, I would completely lose the power steering when I made any left turn. Thank heavens for the AMSOIL.
   / B7500 HST power steering and and 3 point lift problems in high temp. #52
Hey tomf...what Amsoil are you using? thanks
   / B7500 HST power steering and and 3 point lift problems in high temp. #53
   / B7500 HST power steering and and 3 point lift problems in high temp. #54
Tomf
You can try and raise your system relief pressure. or it also sound like a gear to housing issue with your pump (worn out) but if it only happens to a left hand it almost sound like a steering valve problem. probably should start with checking your system relief pressure.
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
KBH 25T Tender (A56438)
KBH 25T Tender...
Murray Push Mower (A57453)
Murray Push Mower...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
