B7500 HST power steering and and 3 point lift problems in high temp.
   / B7500 HST power steering and and 3 point lift problems in high temp. #51
I have a B2400HSD. My tractor does not appear to be plumbed as shown with the return line going directly into the main line. I could be mistaken but this does not seem to apply to my problem. Again, since I've been using AMSOIL hydraulic fluid, with the exception of the first 2 or 3 mowing jobs, I've had zero problems. In the past I used UDT, Super UDT, Bobcat fluid, and TSC fluid. When I was using any of those fluids, after an hour of hard mowing, I would completely lose the power steering when I made any left turn. Thank heavens for the AMSOIL.
   / B7500 HST power steering and and 3 point lift problems in high temp. #52
Hey tomf...what Amsoil are you using? thanks
   / B7500 HST power steering and and 3 point lift problems in high temp. #53
   / B7500 HST power steering and and 3 point lift problems in high temp. #54
Tomf
You can try and raise your system relief pressure. or it also sound like a gear to housing issue with your pump (worn out) but if it only happens to a left hand it almost sound like a steering valve problem. probably should start with checking your system relief pressure.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2002 Miller Trailblazer 301G Towable Welder Generator (A59228)
2002 Miller...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
24017 (A56859)
24017 (A56859)
2012 International Prostar (A56438)
2012 International...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
