b7500 air filter
/ b7500 air filter #1
snowman
Central NY
Kubota B7500HSD
I wanted to change the inner air filter on my b7500 on Saturday; first time it's been changed (113 hours). I could see from the new filter that it appeared that you just pull the old filter out and stick the new one in (versus screwing it in or something).
The old one would not come out; it ended up breaking off. The actual filter part pulled out of the end piece that fits into the airhose.
I could not pull that broken end piece out; I tried to pull it with a pair of pliers, but the plastic part that I could grab onto with the pliers is not strong enough (the pliers would just crush it). I ended up sticking the old filter back on (there was enough of a ring left that it could hold on fairly well).
Is there any trick to this? Thanks in advance if anyone has any suggestions.
/ b7500 air filter #3
I changed the filter a couple months ago (actually, the dealer tech came out, but I was alledgedly taking notes), but I'll be darned if I can remember what was done on that particular item. /w3tcompact/icons/crazy.gif
I do remember it took all of a couple of seconds though. /w3tcompact/icons/smile.gif
The GlueGuy
/ b7500 air filter #4
snowman,
I think jrogers got it, loosen the hose clamp at the rear of the housing and disconnect the hose. The whole thing should come apart easily. If you damaged the secondary element I would replace it before I put any time on the tractor.
Al
/ b7500 air filter
Thanks.
Actually, I loosened up the clamp that holds the air filter housing onto the hose, but the hose was still on the housing so tight that I was afraid that I would break something trying to get it off, which is what usually happen (ie: I had to take the hood off to get to the screw, and I lost the clip pin that holds the hood on). I'll give it another try.
It just seems to me that the inner filter is so fragile that there must have been some other method for me to take it off other than just pulling on it. The housing is too small to get my hand all of the way in to grab the base of the filter to turn it. There was nothing in the manual that I could see to tell how to do this.
/ b7500 air filter #6
Snowman,
The workshop manual is really no better in this area either. The Illustrated parts list has a exploded diagram of the whole thing. With that it's pretty clear how the thing is put together. Sorry about the hood part, the snap pin part number for the hood is, 05525-50800. Left and right sides are the same P/N.
Al
/ b7500 air filter #7
I found this thread while doing a search and looking for information about the inner air filter on the B-series Kubotas. I just replaced the outer air filter on my tractor and had intended to replace the inner one too, but the Parts person at my dealership talked me out of it. I only have about 100 hours on the tractor, but the manual calls for replacement of the inner filter at one year (even if it 'looks clean', I guess).
I'm wondering if other people have bothered to change the inner filter yearly. I'm also wondering how Snowman made out with his /w3tcompact/icons/smile.gif.
/ b7500 air filter #8
If the inner filter looks good I would just leave it alone.
/ b7500 air filter
Wheeldog;
It's still in there.
I made another attempt at getting the housing off a efw months ago. No luck. The rubber base of the inner filter seems to be "fused" into the hose outlet. Can't budge it for anything.
I was using pliers gently, but the plastic is so brittle that little pieces were breaking off, so I left it alone as I didn't want little bits of plastic inside the engine.
Just stuck the inner air filter piece that broke off back on the housing again and intend to leave it there until I die.
Is still perfectly clean. I'm not sure what the need for two air filters is if the outer filter keeps it as clean as it has been.
I guess if I ever really need to change the inner filter, I'll have to buy a whole new air filter housing kit.
/ b7500 air filter #10
Snowman,
Ouch! It sounds like trying to get that filter off was pretty annoying. Given what you said I think I will leave mine alone for the forseeable future.
I'm surprised that more people haven't mentioned a problem with this before - don't the B7500/B2x10 all have a two-filter arrangement?
Take care.
Rob
/ b7500 air filter
Rob;
I don't know what the B2900 series filters are.
Attached is a picture of the part that I can't get out. It's the white "circle" dead center.
/ b7500 air filter
picture didn't take....
/ b7500 air filter #13
I would suggest removing the rear filter housing from the rubber hose that comes off the back. The way the filter fits in the housing you will be able to push it out from the end the rubber hose is attached with a socket or something similar. I just went out and removed the filter from my B7500 to be sure. When I removed mine I was sucessful by rocking the front of the inner filter gently back and forth until it finally let go. The fit is too tight to be pulled straight out. Hope this helps./w3tcompact/icons/smile.gif
Jeff
/ b7500 air filter
Thanks Jeff.
I know it's a simple matter of pulling the hose off. I had the clamp off a month or so ago and was going to do just that, but the way my luck goes, I usually break something while trying to fix something else.
I'll give it another shot next spring, when the snow is gone and the grass is not ready to cut yet. That way I know that I'll have a month or so to get the tractor back into operation if I screw something up!
/ b7500 air filter #15
You sound like me. I never work on anything on a weekend that I wouldn't be able to get help when in trouble.
/ b7500 air filter #16
Wheeldog, I wanted to change my inner filter too and the dealer said that the inner filter did not need changing. So after checking with other posts here several months ago, I left my on. I have over 200 hours on my B7500 and the inner filter looks sparkling clean.
/ b7500 air filter #17
Hi,
On the inner filter my worry will be the possibility that it might start to break apart at some point. Don't want filter pieces being eaten by my engine!
Just have 126 hours on my tractor so far, so I guess I have a bit of time to go yet before I have to start worrying...
Bill in Pgh, PA
