Buying Advice b7100, will a backhoe work on it?
/ b7100, will a backhoe work on it? #1
VTsteader
Southwest Vermont
Kubota B21
Hi,
Not much tractor knowledge YET. I've seen a few B7100's around in my price range and am wondering if a backhoe can be put on it and if so what do I need to look for? And what can I realistically expect to dig with it? - Thanks.
/ b7100, will a backhoe work on it? #2
You would need a frame mount for the backhoe, three points are controversial. Then you would have to buy the back hoe to fit, It would be better to buy together.
DevilDog
Thanks DevilDog. Do you mean buying the tractor and backhoe together (would if I can find one) or finding a backhoe with the frame? Or is the frame specific to the tractor?
Thanks, so much to learn!
/ b7100, will a backhoe work on it? #4
Thanks DevilDog. Do you mean buying the tractor and backhoe togetherYes
(would if I can find one) or finding a backhoe with the frame? Or is the frame specific to the tractor?Specific to tractor
DevilDog
/ b7100, will a backhoe work on it? #5
What type of work were you intending for the backhoe?
Backhoes have been used on the B7100. A new backhoe would be worth much more than the tractor. Subframes can be fabricated.:)
Thanks for the optimism Egon!
I'm not looking to dig a skyscraper foundation or anything just some trenches, pier holes and a root cellar into the side of a hill. What do you think?
I've seen some used backhoes around, is there a specific size I should not go over? I can fabricate a subframe if I see a pic of one.
rob
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2016 Clemett Tri Axle End Dump Trailer (A64047)
2016 Clemett Tri...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Pallet of Safety Cones (A64047)
Pallet of Safety...
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
SET OF (20) ACE CATTLE PANELS W/CONNECTION JOINTS (A63569)
SET OF (20) ACE...
