B7100 3 Point Lift Problem
/ B7100 3 Point Lift Problem #1
jgerni
I've got an early 80s B7100D 4wd tractor with around 800 hours on it. For about the past year the 3 point hitch has become increasingly jumpy and screeches when under load. What could cause this or better yet what do I need to do to fix. I have never changed the tranny fluid and it seems to be reading at the correct level.
Thanks in advance for any info or advice.
/ B7100 3 Point Lift Problem #2
I have a late 70s B6100D 4wd. According to the owner's and repair manuals, it's very similar to the B7100. In my 6100, the tranny fluid is used for the 3 point hitch. Mine screeches when raised all the way up. That's the pressure relief valve actuating.
I'd suggest you change your tranny fluid and check/replace your filter as a first step. Could solve your problem for minimal cost and it's probably due for a change anyway (mine is... :eek: )
Bill
Where is the filter for the tranny fluid. The tranny fluid is just hydrolic fluid correct? I believe mine manual says that it will take 3 gallons to replace.
/ B7100 3 Point Lift Problem #4
Follow the suction line back to the sump. You'll see what looks like a bolt holding it to the differential. That's the filter. It's actually a hollow bolt with a mesh strainer on the end. You can clean the strainer and reuse it. I replaced the "o" rings on mine when I did it. The hydraulic lines are on the right side. The suction line is the larger of the two.
For the fluid use UDT.
I forgot to mention it but drain the tranny before you remove the strainer. There should be three drain plugs on the tranny. Also have a drain pan under the strainer before you remove it or you get tranny fluid on the driveway. I saw that happen once to someone I know.
Rodger
2022 EZ-GO ELITE...
2017 Chevrolet Express 3500 14FT Box Truck (A61573)
2017 Chevrolet...
Informational Lot - Shipping (A63689)
Informational Lot...
UNUSED 1RANCH 1RET13 ELECTRIC TRICYCLE (A64280)
UNUSED 1RANCH...
Caterpillar 966C Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 966C...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
