B7100 3 Point Lift Problem
/ B7100 3 Point Lift Problem #1
jgerni
I've got an early 80s B7100D 4wd tractor with around 800 hours on it. For about the past year the 3 point hitch has become increasingly jumpy and screeches when under load. What could cause this or better yet what do I need to do to fix. I have never changed the tranny fluid and it seems to be reading at the correct level.
Thanks in advance for any info or advice.
/ B7100 3 Point Lift Problem #2
I have a late 70s B6100D 4wd. According to the owner's and repair manuals, it's very similar to the B7100. In my 6100, the tranny fluid is used for the 3 point hitch. Mine screeches when raised all the way up. That's the pressure relief valve actuating.
I'd suggest you change your tranny fluid and check/replace your filter as a first step. Could solve your problem for minimal cost and it's probably due for a change anyway (mine is... :eek: )
Bill
Where is the filter for the tranny fluid. The tranny fluid is just hydrolic fluid correct? I believe mine manual says that it will take 3 gallons to replace.
/ B7100 3 Point Lift Problem #4
Follow the suction line back to the sump. You'll see what looks like a bolt holding it to the differential. That's the filter. It's actually a hollow bolt with a mesh strainer on the end. You can clean the strainer and reuse it. I replaced the "o" rings on mine when I did it. The hydraulic lines are on the right side. The suction line is the larger of the two.
For the fluid use UDT.
I forgot to mention it but drain the tranny before you remove the strainer. There should be three drain plugs on the tranny. Also have a drain pan under the strainer before you remove it or you get tranny fluid on the driveway. I saw that happen once to someone I know.
Rodger
2006 PITTS 4 BOLSTER LOG TRAILER (A64276)
2006 PITTS 4...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2012 Chevrolet Silverado 1500 Pickup Truck (A61573)
2012 Chevrolet...
1143 (A63745)
1143 (A63745)
