B7001 starting problems
/ B7001 starting problems #1
65SDkarl
Oyster River
KubotaB7001
I know it's a grey market but it is a starting problem and this seemed the place to query. When I turn the key to get the glow plugs going sometimes it works sometimes it doesnt. But when I go to start I get nothing. This all started when I stalled it as I went thru a rut, it made a 'clunk' sound as it stalled. I went to start and got nothing. I brought my truck ot and jumped it and it started no problem. I took the battery out and had it tested and it was low but I had it charged for a couple of hours on a deep cycle charger and was told the battery was good. Re-installed the battery, glow plugs came on, went to start, small pop and smoke from positive terminal and then nothing. I can still jump start it and when it's running at operating speed the volt reading at the battery seems high, approx 15-17 volts depending on engine speed. Suggestions?
/ B7001 starting problems #2
The bat. cable terminal may be bad. corroded inside.
/ B7001 starting problems #3
Sounds like a bad connection in the starter circuit. Inspect and clean both ends of each battery cable. And as Flylo said, could be a bad cable too.
Fixed! It's always the easy ones that seem to stump me
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2019 CATERPILLAR 315FL CR EXCAVATOR (A65056)
2019 CATERPILLAR...
2023 Unused Monroe Tufline TW92420 9ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
2023 Unused Monroe...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2027 . . (A67714)
2027 . . (A67714)
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
