Oil & Fuel B6000E UDT oil ???????
   / B6000E UDT oil ??????? #1
Calbear55
California
Kubota B6000E
I have a question, what is the difference between a Kubota UDT oil and a 80-90wt gear oil. I want to change the Trans. and Hyd. Before I do this I want to make sure I am not doing something stupid.:( I am working on a shoestring budget(like out of my pockets:)) Any help will be appreciated :D
   / B6000E UDT oil ??????? #2
This is what I think I know, but I'm no expert. UDT is meant to be more of a hydraulic fluid, where the gear oil is meant to run in axles, such as the front axle of a 4wd tractor. I have also seen gear oil used in manual transmissions on cars and trucks. I don't think they can be interchanged, but I'm not sure.
   / B6000E UDT oil ??????? #3
I would not substitute gear oil for UDT. I'm not that familiar with the requirements of a B6000E, but if it calls for UDT, stick with that. You can buy another brand of UDT as long as it meets the spec, but don't use gear oil.
   / B6000E UDT oil ??????? #4
Service manual says SAE 80 gear oil...9L (2.38 gal). Use SAE 80 in the tiller also. But use hydraulic fluid in the loader.
Thanks all! I should have re read my post. Had my head in the clouds this morning:mad:. Should have stated "Can I use a any Hydraulic/Trans. oil in place of Kubota UDT oil"
2017 Ram 4500 Bucket Truck (A51039)
2017 Ram 4500...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A50854)
2011 ORTEQ ENERGY...
2018 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A51219)
2018 VOLVO...
WEATHERGUARD TOOLBOX (A50854)
WEATHERGUARD...
LOT LOCATIONS (A51219)
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A51039)
Adams FL24...
