B414 glowplugs
/ B414 glowplugs #1
DLTTrekkers
Paarl South Africa
I am sitting with a B414 that blow the no4 glowplug as soon as you want to start it.
I have trased the wiring and all looks normal.
I did not test the glowresistor bcz I do not know what that value must be.
/ B414 glowplugs
I found tbe problem.
The front tip of the glowplug touch the combustioncamber and made a short.
I used a drillbite and drilled it out. Then a magnet to pick-up the shavings and reinstall the glowplugs
/ B414 glowplugs #3
nice work findingthat
/ B414 glowplugs
Messure the size here plus 1.5mm and drill the sides away of the inner comb chamber 20180921_063517.jpeg
/ B414 glowplugs #5
Great find.. & as it turns out, an easy fix..
Was it a casting flaw??
/ B414 glowplugs
Not a casting flaw but a engineering mistake. When they test an recon the silinderhead they had to remove the combustionchambers to replace the copperwashers . With the rebuilding they rotate it just a little and the skimmed the top.
After I essemble the engine I did not want to remove the silinderhead again to loosen the combustionchambers to rotate it to the correct posision.....so I just drilled that little bit out.
New/Unused Pallet of 250 Traffic Cones (A65583)
New/Unused Pallet...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
Skull (A64557)
Skull (A64557)
2014 Takeuchi TB260 Midi Excavator (A64553)
2014 Takeuchi...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
