B414 glowplugs
/ B414 glowplugs #1
DLTTrekkers
Paarl South Africa
I am sitting with a B414 that blow the no4 glowplug as soon as you want to start it.
I have trased the wiring and all looks normal.
I did not test the glowresistor bcz I do not know what that value must be.
/ B414 glowplugs
I found tbe problem.
The front tip of the glowplug touch the combustioncamber and made a short.
I used a drillbite and drilled it out. Then a magnet to pick-up the shavings and reinstall the glowplugs
/ B414 glowplugs #3
nice work findingthat
/ B414 glowplugs
Messure the size here plus 1.5mm and drill the sides away of the inner comb chamber 20180921_063517.jpeg
/ B414 glowplugs #5
Great find.. & as it turns out, an easy fix..
Was it a casting flaw??
/ B414 glowplugs
Not a casting flaw but a engineering mistake. When they test an recon the silinderhead they had to remove the combustionchambers to replace the copperwashers . With the rebuilding they rotate it just a little and the skimmed the top.
After I essemble the engine I did not want to remove the silinderhead again to loosen the combustionchambers to rotate it to the correct posision.....so I just drilled that little bit out.
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A64556)
2016 Chevrolet...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
1949 GMC 1 Ton Flatbed Original Truck (A65583)
1949 GMC 1 Ton...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Grain-O-Vator Silage / Feed Wagon (A66408)
Grain-O-Vator...
Welcome to the Farm Metal Sign (A65583)
Welcome to the...
