B414 glowplugs
/ B414 glowplugs #1
DLTTrekkers
Paarl South Africa
I am sitting with a B414 that blow the no4 glowplug as soon as you want to start it.
I have trased the wiring and all looks normal.
I did not test the glowresistor bcz I do not know what that value must be.
/ B414 glowplugs
I found tbe problem.
The front tip of the glowplug touch the combustioncamber and made a short.
I used a drillbite and drilled it out. Then a magnet to pick-up the shavings and reinstall the glowplugs
/ B414 glowplugs #3
nice work findingthat
/ B414 glowplugs
Messure the size here plus 1.5mm and drill the sides away of the inner comb chamber 20180921_063517.jpeg
/ B414 glowplugs #5
Great find.. & as it turns out, an easy fix..
Was it a casting flaw??
/ B414 glowplugs
Not a casting flaw but a engineering mistake. When they test an recon the silinderhead they had to remove the combustionchambers to replace the copperwashers . With the rebuilding they rotate it just a little and the skimmed the top.
After I essemble the engine I did not want to remove the silinderhead again to loosen the combustionchambers to rotate it to the correct posision.....so I just drilled that little bit out.
2005 International 5900i T/A Gardner Denver Kill Truck (A64194)
2005 International...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
2013 Kia Rio Passenger Car, VIN # KNADM4A36D6319585 (A64557)
2013 Kia Rio...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
