B3300 Throttle Problem...
   / B3300 Throttle Problem... #1
dnels0n
I am up to 10 hours on the B3300, the biggest problem I have noted is the throttle now moves back to idle after a few seconds if the tractor is moving. I have tried to figure out where the tension adjustment is. The dealer is a 120 mile round trip! Anyone else see this, have an idea how to adjust it?
Thanks,
Don
   / B3300 Throttle Problem... #2
If you follow the throttle down close to the floorboard you should see a spring and a nut at the end of the throttle rod. Try to tighten the nut for more tension. I'm not sure about your machine but this is how it works on my L3400. I got tired of always having to slap mine so I took some tension off mine. It still holds the position but is much easier to operate now. Hope this helps.
Thanks JAE, I'll have a second look but I think mine is different.
Don
Don
Yep, you were right, sounds like they were similar, 12 mm open end just squeezed in with enough room to tighten it a bit.
Thanks again.
Don
Thanks again.
Don
Of course it comes loose every 4 hours or so! The Jam nut was missing, and when I tried to put a new one on I dropped it, so I figured out how to raise the console skirt(remove screw on top, push everything straight up) and while looking for the nut I bought I found the original jam nut! :)
Hoping no more problems there.
Don
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2012 Geringhoff NS1200 Corn Head (A50657)
2012 Geringhoff...
Pallet of Turnbuckles (A50860)
Pallet of...
2016 International ProStar T/A Sleeper Truck Tract (A50860)
2016 International...
Harrow Drag (A50860)
