B3030 relief valve
/ B3030 relief valve #1
Stef
Platinum Member
South Quebec, Canada
Kubota B3030 TLB, TYM 330
Does anyone know the shim's thickness coming fact. on a B3030 relief valve? /forums/images/graemlins/confused.gif It can be 0.1mm, 0.2mm or 0.4mm (2175 to 2320 psi). I've included a drawing of the valve with part numbers in PDF file format to show you what I'm talking about. /forums/images/graemlins/wink.gif Any thought could be helpful. Thanks
  • 901965-relief valve B3030.pdf
/ B3030 relief valve #3
Stef…
Relief valves use shim stock to make allowances to the fact that you can not mass produce valves/springs exact.
The relief valve is set to the correct pressure for its application by using various shim thicknesses… I don’t think you would necessarily find a dozen in a row using the same shim thickness and producing the same pressure. KennyV.
BTW are you changing your pressure?
/ B3030 relief valve #4
Stef…
KennyV, thanks, you're probably right. But I wonder why the max pressure varies between 2175 to 2320 psi? (see attachment) But again, your explanation could be right about that too. Different spring, different pressure. A bit more for a B2630 (2204 to 2349 psi) because the pump turns faster (2800 rpm compared to 2600 for a B3030).
No I'm not changing the pressure. But here's the reason why I ask technical questions: I have no leak down whatsoever on my FEL and my backhoe BH75 leaks a lot so I'd like to try to fix it.
<ul type="square"> 1) I try to understand the whole hydraulic system of my B3030.
2) As I said, no leak down for my FEL LA403. It means, the cylinders and the control valve of the loader are well sealed.
3) No leak down of the 3PH and the hydraulic system of the tractor is great.
4) So it's either or both: the backhoe cylinders or the BH75's control valve. It was great when new and then it started to leak. Maybe metal chips travelled into the hydraulic system and cause some seals to malfunction. I saw my tractor on the parking lot of my dealer, the backhoe up, no sign of leak down for hours even days.
5) I'll start by testing all the cylinders individually (7 of them) to see if they leak or maintain their pressure over a definite period of time (let's say a couple of hours 2 to 4). If all the cylinders pass the pressure test then it's the control valve.
6) Look at the valve. I'd start by checking the relief valves mounted on the valve (6 of them: 2 for dipper, 2 for boom and 2 for swing). [/list]
What I don't understand yet is:
<ul type="square"> 1) Why there's no relief valve for the bucket and stabilizers? The only explanation I can see so far is: they use the max pressure the tractor can provide so the only relief valve needed is the one on the tractor. The dipper, boom and swing use lower max pressure so they need relief valves with lower settings.
2) When my BH75 leaks down, all the cylinders are affected: bucket, dipper, boom, stabilizers (swing? I don't know, it's hard to tell it cannot leak "down"). What could cause a leak down of everything and not only one cylinder? I think this is a crucial information to be able to pinpoint the problem efficiently but I don't know what to think about it yet. [/list]
The backhoe of my former BX23 had virtually no leak down. The one I own now lies on the floor in two hours so I'm pretty sure I can do something about it. I have to pinpoint the problem and solve it. Engineers, show yourselves /forums/images/graemlins/wink.gif
/ B3030 relief valve #7
The relief valve should have nothing to do with leak down. The reason there is a relief on each work port for the dipper, boom and swing is to prevent damage to the hydraulic system if you use one of those functions past their limits in either direction. For example, trying to lift something too heavy or pushing against an immoveable object. My 1963 TD6 dozer has a relief on each work port of the lift and curl spools too.
Relief valves work when the pressure exceeds a certain point. That point is determined by a calibrated spring with shims. The relief spring will compress and open a direct path to the tank circuit. Now if you have a broken spring or maybe a very, very weak spring then it might cause leakdown. I don't think that is your problem.
/ B3030 relief valve #8
/ B3030 relief valve #9
Stef
Your logic sounds good…
Finding a leak down can be a problem. You might find a fast, like yours, using a stethoscope, either electronic or conventional. You will need to have everything around rather still and quiet, then as you near the leak you will hear it.
Multi viscosity oil can leak down where a strait weight may not. There are no real seals in many control valves, close machine tolerances usually give acceptable leak down, most leaks like you have outlined are in the control valve. Good luck and happy hunting.
Should you locate, post back with your findings…KennyV.
/ B3030 relief valve #10
Stef
/ B3030 relief valve #11
I think Mad is right about the relief valve not being a prime suspect… If a work port had a relief spring that far off you would certainly notice it as being very weak in that function during normal use… KennyV.
/ B3030 relief valve #12
/ B3030 relief valve #13
Is this excessive leakdown?
Once the valve spools have been used they start to wear. Spool rod surfaces with no tolerance when new now have some. Even the slightest scratch will cause some leakdown. Scratches can be caused by microscopic particules in the fluid and burrs and imperfections on the valve casting where it meets the spool rod (common with new equipment). Also, the relief and load check poppets may not be seated tightly due to crud. Since this is a fairly new tractor any of the above may be causing your leakdown. However, leakdown is inevitable and a fact of life.
BTW, if you decide to adjust the relief springs with shims to get additional oomph for your backhoe, make sure you do not exceed the system pressure. Doing so will negate the reason for having the reliefs. Use a proper gauge connected correctly.
/ B3030 relief valve #14
/ B3030 relief valve #15
</font><font color="blue" class="small">( Stef
)</font>
I agree with KennyV, leakdowns like you are describing are usually in the control valves. Not sure if this is excessive enough to justify warranty repair or if that's applicable???
/ B3030 relief valve #16
)</font>
2000 Kubota KX121-3ST Mini Excavator (A61572)
2000 Kubota...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
Timberjack 608B FellaBuncher (A62679)
Timberjack 608B...
1993 Ford F-150 Ext. Cab Pickup Truck (A61573)
1993 Ford F-150...
