B3030 engine cutting out for no apparent reason
   / B3030 engine cutting out for no apparent reason
After thinking about this situation, I remembered that I cranked the seat spring up to near the max, because I kept bottoming out when mowing my field. So, the seat may well be sitting higher than "expected"
So I did a cheat that I have done on a few unrelated applications - add a coin (a nickel always in my case), taped over the plunger/sensor/what-have-you. It takes up the slack without having to do anything more complicated.
Yes, I taped a nickel to the bottom of my seat where the sensor plunger hits it. Did a cleanup tonight and not a single cut-out. Then again, I never had one for 5 years prior, FWIW.
   / B3030 engine cutting out for no apparent reason #12
Often overlooked is the ignition switch and your problem sounds like a safety switch or ignition switch
202482 (A54757)
202482 (A54757)
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB46449, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
Welding machine (A56857)
Welding machine...
2012 PJ Trailers PJFS25 25ft 7 Ton T/A Gooseneck Dovetail Flatbed Equipment Trailer (A55973)
2012 PJ Trailers...
