B3030 clutch question
/ B3030 clutch question #1
Bowhunter
southwest Indiana
Kubota BX2200
Forgive my ignorance on this topic. I've read in various posts here that the B3030 does not have a foot clutch, but instead has a had operated electric or hydraulic (can't remember which) clutch. Henro has voiced concerns about operating a PHD with this type clutch, and I agree with him wholeheartedly. My question is for those members that have had a chance to use their B3030's already, especially with a rotary cutter. How well does the new-fangled clutch work with heavy 3ph attachments like the rotary cutter, a tiller, etc?
Sorry, I try to practice the motto of "if it ain't broke don't fix it" and I feel like Kubota tried fixing something that wasn't broke with this hand clutch. Having no hands-on experience with one though, I could be completely off-base.
/ B3030 clutch question #2
Just thought I'd bump this one up to the top of the heap and see if it gets some replies - I'm wondering about the clutch setup on the Bxx30 as well. Anyone have some thoughts, especially concerning PHD use?
/ B3030 clutch question #3
I have only used a 5' brush-cutter so far, but have experienced absolutely no problem. I only engage/disengage at idle.
/ B3030 clutch question #4
Cart99:
Thanks for the reply. Any chance you could take the time for a brief description of how the clutch system works on your 3030? Is there a hand clutch that can be used to "feather" the PTO? If so, is it mechanical, electric, hydraulic? So many questions, so little "planet time". /forums/images/graemlins/tongue.gif
Thanks, John D.
OBTW - I'd love to see a pic of the grapple - sounds like just the ticket for someone I know - thanks.
/ B3030 clutch question #5
Same here, engage at idle in one smooth motion. The dealer has informed me that it's a hydraulic multi plate(9 plates ?) system that will last years. It is very quiet and it doe's shift smooth. 12 hours so far and my left leg is still operating a pedel thats not there
/ B3030 clutch question #6
There's no feathering possible, the lever is essentially a light switch...it's either on or it's off. There have been several posts in the past that if you plan to do things like run a post-hole digger or something else where a greater degree of control over the rear PTO is required, you'd actually be better off with a B7800 versus the B3030. I have two helpful neighbors that have clutch tractors and post-hole diggers, so I wasn't concerned about this.
/ B3030 clutch question #7
</font><font color="blue" class="small">( OBTW - I'd love to see a pic of the grapple - sounds like just the ticket for someone I know - thanks. )</font>
Always happy to show off the ATI/Messick's Grapple
/ B3030 clutch question #8
I use a 5' brush hog to cut my 7 acres of imperial whitetail clover food plots and weeds that seem to grow 6' tall. It works well for this. I don't know how it works, but it does.
/ B3030 clutch question #9
More specifically, how well does the independent PTO work while using a post hole digger? Any problems?
Darrell
/ B3030 clutch question #10
I have not had any problems operating my phd with the 2630.
/ B3030 clutch question #11
Hi, I've got a B3030 w/ Gearmore 5' HD rotary cutter. I've logged 127 hrs on it this year, most of those with the rotary cutter, and I've experienced no problems with the PTO engagement. As others have mentioned, if engaged at idle, it's smooth with no "jumpy" start. I did engage the PTO one time above idle to loosen a "stuck" blade on the cutter, and promptly broke the shear pin!
2000 INTERNATIONAL 4900 - 10 WHEELER GRAIN TRUCK (A64278)
2000 INTERNATIONAL...
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
2023 KUBOTA SVL97-2 SKID STEER (A65053)
2023 KUBOTA...
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
2023 Chevrolet Tahoe SUV (A64557)
2023 Chevrolet...
