B2920 and 5ft bushhog
/ B2920 and 5ft bushhog #1
cgreenway
Tennessee
09 Kubota B3030HSD-F
Hey out thier , any B2920 owners use a 5' bush hog and a 5' boxblade??, the dealers have been swearing my buddie off of the b2920 and telling him he needs a bigger unit, B3030 or so, the price difference between the 2 around here are about 4k, so its a bit of money, he only has a bout 2 acres to bush hog and use a box blade in his yard and ect, and he's gonna use it to mow his yard the remander of the time, I think he could get away with the B2920, with his field being somewhat level, thanks,
/ B2920 and 5ft bushhog #2
I'd say the 5' bush hog will be fine as long as he has enough weight on the front. I'd probably do a 54" boxblade though.
/ B2920 and 5ft bushhog #3
I use a 4ft. BB on my 2620 and it pulls it no problem. (about 475 lbs) I actually sometimes wish I bought the 5 footer but they didnt have any in stock at the time of purchase so I got a discount on the 4' If their is a loader on the tractor this should supply ample weight in the front to offset the brush hog
/ B2920 and 5ft bushhog #4
It will pull the 5' hog fine. Sure... you can bog it down... but you could with a 40hp tractor also. Weight shouldn't be a problem as long as it is a medium to light duty cutter and you have a FEL or weights on the front. I actually pull a 5' with my 18hp/15 PTO hp tractor. It does fine as long as I pace myself to the conditions. The box blade might not work quite as well. If you are just smoothing out the driveway or something it would be fine. But pulling a load of dirt or running with the scarifiers down the tractor just doesn't weigh enough to be real efficient. A 54" might be a better choice... kinda depends on what you want to use it for.
/ B2920 and 5ft bushhog #5
I use a 5 foot rotary cutter on my 3030. It handles it with no problem. I should have gotten a 6 foot one. I do keep the loader on to add counter weight to the front. You should have no problem with a 5 footer. I have a 5 foot box blade. It is wide enough to cover the track of the rear wheels. When the box fills up I need to put it in 4 wheel drive when grading the steep part of my road. I think a 5 foot blade might be a little big for you.
/ B2920 and 5ft bushhog #6
I just got my new 2920 home on December 22 and I would not hesitate to put a 5 foot weed mower behind it. I did use my 5 foot light weight weed mower behind mine in dry weeds and it handled it just fine. I had a 6 foot rear blade behind it and a 5 foot box blade(King Kutter). The 2920 has plenty of power for its size. I would only hesitate in hills and then only to keep the front end on the ground. My next challenge will be to see if I will be able to pull my 6 foot tandem disc.
/ B2920 and 5ft bushhog #7
Have had a B2920 since mid summer. Pull Woods 65" heavy duty box scraper without any issue. A freind borrowed it the cut sunflowers before dove season and then cut paths in his crp with a 6' brush hog that he owns after his 45hp was involved in a flood. He said it had plenty of power but since his tractor sat a least a foot higher he was concerned with high centering it crossing waterways.
