B2710 Hydraulic Case/Tank Return
   / B2710 Hydraulic Case/Tank Return #1
bnold
Have a B2710 I’d like to add a set of rear remotes to.
Have the valve with open center/Power beyond kit as well as the Kubota hydraulic piece to mount on the side of the transmission case. (Plate is removed and this piece is bolted in its place for an hydraulic in/out). Question is, I believe this plate is before the pressure relief valve in the system, so I need to use the T port on the valve to dump back to the tank.
Not sure where to do this other than the fill port on the transmission case.
Help appreciated!
   / B2710 Hydraulic Case/Tank Return #2
Help appreciated!
If you have a loader, Tee into the Tank line of the loader valve.
Dave M7040
No loader on this one.
   / B2710 Hydraulic Case/Tank Return #4
Found the tank return this weekend from the images in that thread, much appreciated!
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
2014 Ford F-350 Omaha Crane Service Truck (A48081)
2014 Ford F-350...
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
2020 Chevrolet Express 2500 Animal Control Cargo Van (A48081)
2020 Chevrolet...
UNUSED Plastic Mesh Safety Fencing Roll (A50860)
UNUSED Plastic...
