B2710 Hydraulic Case/Tank Return
   / B2710 Hydraulic Case/Tank Return #1
bnold
Have a B2710 I’d like to add a set of rear remotes to.
Have the valve with open center/Power beyond kit as well as the Kubota hydraulic piece to mount on the side of the transmission case. (Plate is removed and this piece is bolted in its place for an hydraulic in/out). Question is, I believe this plate is before the pressure relief valve in the system, so I need to use the T port on the valve to dump back to the tank.
Not sure where to do this other than the fill port on the transmission case.
Help appreciated!
   / B2710 Hydraulic Case/Tank Return #2
Help appreciated!
If you have a loader, Tee into the Tank line of the loader valve.
Dave M7040
No loader on this one.
   / B2710 Hydraulic Case/Tank Return #4
Found the tank return this weekend from the images in that thread, much appreciated!
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
1999-2010 Ford Pickup Truck Bed (A55973)
1999-2010 Ford...
2019 FREIGHTLINER SD122 DAY CAB (A57880)
2019 FREIGHTLINER...
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
