B2710 Hydraulic Case/Tank Return
   / B2710 Hydraulic Case/Tank Return #1
bnold
Have a B2710 I’d like to add a set of rear remotes to.
Have the valve with open center/Power beyond kit as well as the Kubota hydraulic piece to mount on the side of the transmission case. (Plate is removed and this piece is bolted in its place for an hydraulic in/out). Question is, I believe this plate is before the pressure relief valve in the system, so I need to use the T port on the valve to dump back to the tank.
Not sure where to do this other than the fill port on the transmission case.
Help appreciated!
   / B2710 Hydraulic Case/Tank Return #2
Help appreciated!
If you have a loader, Tee into the Tank line of the loader valve.
Dave M7040
No loader on this one.
   / B2710 Hydraulic Case/Tank Return #4
Found the tank return this weekend from the images in that thread, much appreciated!
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
Forklift Safety Basket (A56857)
Forklift Safety...
2003 Big Tex 10PI...
2020 John Deer 3038E 4 x 4 Tractor w/300 E Loader, S/N 1LV3038EJKK126097, Diesel Engine, Joystick (A59076)
2020 John Deer...
Kimball Midwest Wire Cabinet w/Wire (A59076)
Kimball Midwest...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
