B2650 SNOWBLOWER
/ B2650 SNOWBLOWER #1
ZZZ2D1
PRUDENVILLE, MI
2005 JOHN DEERE 4115 SOLD - 2014 NEW KUBOTA B2650 - AND - 2011 KUBOTA RTV 1100
Is the new Kubota B2650 have enough @ 26 hp for the 63 inch snow blower?
My John Deere 4115 had a 47 inch snow blower @ 24 hp and that with 8-10 inches of snow would start to lug down pretty good.
Any thoughts and comments appreciated.
/ B2650 SNOWBLOWER #2
Kubota manuals usually have a table showing maximum recommended implement size.
/ B2650 SNOWBLOWER
Actual real data comes from the end user, not what the manuals says.
Some auto manufacture's built 4 wheel drive pickup's with 4 cylinder engines that were terribly underpowered..
/ B2650 SNOWBLOWER #4
Depending on the snow depths or weight of snow (wet sticky snow) there will be times when the blower will lug down.
I assume you have a Hydrostatic transmission on your B2650 .. just slow down on the ground speed and keep the pto speed up.
For the past 8 years I have used a Kubota B7800 (30hp) with a 64 inch rear mount snowblower,
and when the snowblower lugs down a little I just decrease my ground speed.
After most snow storms I don't usually run my snowblower at the max 540 pto speed.
540 rpm pto is 2650 rpm engine speed on the B7800, I usually snowblow at 2000 rpm engine speed.
8-10 inches snow I'd run at 2000 rpm, unless it was really wet snow, then I'd run at full 2650 rpm (540 Pto rpm).
/ B2650 SNOWBLOWER
Yes, that is what I usually do and did with my John Deere 4115.
But with only 2 more HP and 16" more width on the snowblower - the math does not ad up.
I guess we'll see when we get 8-10" of snow.
Thanks for the reply.
/ B2650 SNOWBLOWER #6
I have a 2014 B2650 tractor with cab and a 2682B snow blower which is 72" long and have no issues, I blow in medium gear.
Bomag Roller (A63689)
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
2014 Freightliner 114SD T/A Dump Truck (A64556)
2014 Freightliner...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
