B2650 radiator cap stuck
/ B2650 radiator cap stuck #1
Rob 80
WVA
B2650
Trying to check my radiator fluid level and i can't get the radiator cap off!! You turn it it releases but will not come off. I'm scared i could brake off the radiator top since it is only plastic.
Should i just force it, usually they have two tabs that hold it on maybe they are bent in to much.
/ B2650 radiator cap stuck #2
push down on it, then twist off.....never force
check overflow reservoir as well
/ B2650 radiator cap stuck #3
As far as I know................what bubba said.
/ B2650 radiator cap stuck #4
x2
Don't force.
They do come off.
One of my vehicles I just change the coolant on has a tough little bugger of a cap.
/ B2650 radiator cap stuck #6
as you firmly push down also twist cap counter clockwise in one action.
place your right palm (if you're rh) on cap, then left hand over right, firmly press down & twist.
get a rhythm going, like doing cpr to the radiator.....best regards :)
Maybe it will come off easier if cold versus hot.
It is cold actually, i did get it off! It's over filled maybe that is why it is hard to get off...more pressure.
/ B2650 radiator cap stuck #9
doubt it. the overflow reservoir would take care of that.
just that the cap probably not removed very often
/ B2650 radiator cap stuck #11
Just my 2cents, get another cap or have the old tested to make sure it releases at the proper pressure. Cheaper than a new rad
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2015Ford Escape SUV (A61574)
2015Ford Escape...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2022 EZ-GO ELITE...
