B2650 radiator cap stuck
/ B2650 radiator cap stuck #1
Rob 80
WVA
B2650
Trying to check my radiator fluid level and i can't get the radiator cap off!! You turn it it releases but will not come off. I'm scared i could brake off the radiator top since it is only plastic.
Should i just force it, usually they have two tabs that hold it on maybe they are bent in to much.
/ B2650 radiator cap stuck #2
push down on it, then twist off.....never force
check overflow reservoir as well
/ B2650 radiator cap stuck #3
As far as I know................what bubba said.
/ B2650 radiator cap stuck #4
x2
Don't force.
They do come off.
One of my vehicles I just change the coolant on has a tough little bugger of a cap.
/ B2650 radiator cap stuck #6
as you firmly push down also twist cap counter clockwise in one action.
place your right palm (if you're rh) on cap, then left hand over right, firmly press down & twist.
get a rhythm going, like doing cpr to the radiator.....best regards :)
Maybe it will come off easier if cold versus hot.
It is cold actually, i did get it off! It's over filled maybe that is why it is hard to get off...more pressure.
/ B2650 radiator cap stuck #9
doubt it. the overflow reservoir would take care of that.
just that the cap probably not removed very often
/ B2650 radiator cap stuck #11
Just my 2cents, get another cap or have the old tested to make sure it releases at the proper pressure. Cheaper than a new rad
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61568)
1987 International...
2008 CATERPILLAR 304C CR EXCAVATOR (A62129)
2008 CATERPILLAR...
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
set of 4 tractor trailer tires Roadforce (A63118)
set of 4 tractor...
JOHN DEERE 344H WHEEL LOADER (A63276)
JOHN DEERE 344H...
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
