B2650 radiator cap stuck
/ B2650 radiator cap stuck #1
Rob 80
WVA
B2650
Trying to check my radiator fluid level and i can't get the radiator cap off!! You turn it it releases but will not come off. I'm scared i could brake off the radiator top since it is only plastic.
Should i just force it, usually they have two tabs that hold it on maybe they are bent in to much.
/ B2650 radiator cap stuck #2
push down on it, then twist off.....never force
check overflow reservoir as well
/ B2650 radiator cap stuck #3
As far as I know................what bubba said.
/ B2650 radiator cap stuck #4
x2
Don't force.
They do come off.
One of my vehicles I just change the coolant on has a tough little bugger of a cap.
/ B2650 radiator cap stuck #6
as you firmly push down also twist cap counter clockwise in one action.
place your right palm (if you're rh) on cap, then left hand over right, firmly press down & twist.
get a rhythm going, like doing cpr to the radiator.....best regards :)
Maybe it will come off easier if cold versus hot.
It is cold actually, i did get it off! It's over filled maybe that is why it is hard to get off...more pressure.
/ B2650 radiator cap stuck #9
doubt it. the overflow reservoir would take care of that.
just that the cap probably not removed very often
/ B2650 radiator cap stuck #11
Just my 2cents, get another cap or have the old tested to make sure it releases at the proper pressure. Cheaper than a new rad
2016 GMC Acadia AWD SUV (A61569)
2016 GMC Acadia...
6059 (A61165)
6059 (A61165)
2016 CATERPILLAR AP1000F ASPHALT PAVER (A62129)
2016 CATERPILLAR...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A62129)
2015 CATERPILLAR...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
