B2650 on the way
   / B2650 on the way #51
The steering wheel changing position is part of a hydrostatic steering system. This setup has no hard direct link between the steering wheel and the front end. Perfectly normal.
I think you better find an orange spinner so you can get back that 5 hp that green one is sapping out of your machine. :)
   / B2650 on the way #52
That is just funny right there. And, I concur! :D
   / B2650 on the way
I got the spinner moved, much better! Still green though. Almost popped a wheelie in the back yard, had to idle it down a bit :D
   / B2650 on the way #55
If it won't crank when you go to use it I would suggest that JD suicide knob be removed tractors are very senstive:cool2:
   / B2650 on the way
Anybody know the deal with the wheel/tire sizes on these? For instance why does the B series have "balloon" tires as I call them, small rims and tall tires therefore a lot of sidewall - vs. an L series which has much larger rims and lower profile tires? Does that allow increased capacity on larger tractors? Or are they just trying to keep the smaller ones a little more squishy/comfortable for the homeowners since that's the market for the smaller tractors?
   / B2650 on the way #57
Good question. On my L I had an option of 26" or 28" rims, I went with the 26" because it was a wider tire option and slightly taller. My ford has the 28" rim.
   / B2650 on the way #58
You can get both types on the B3350 -- they have the small R4 option and the large R4 option (which happens to match the tires on my L3200).
As far as sizing between B and L, I'm sure it has everything to do with weight. The B models are feather weights.
   / B2650 on the way #59
Great comments here on this post - especially the issues you've had. I just pulled the trigger on a new B2650 myself. I'll take note of the issues you had and make sure to let my dealer know. I wanted a bigger one (L3301) but the war dept (wife) nixed that one. The L3301 was about another $6K too. Delivery on Friday (3 day total). Below is the tractor being set up. Apparently when they're delivered to dealers all boxed up in a crate. I was surprise to see that even the rear wheel lugs were not pressed in. Anyway, looking forward to pushing dirt around this weekend. IMG_9367.jpg
   / B2650 on the way #60
It's impressive seeing them all crated up, not much wasted space.
2005-  3412 ENGINE (A50854)
2005- 3412 ENGINE...
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
