Comparison B2601 vs. LX2610
/ B2601 vs. LX2610 #21
Non-commercial flails used on rough cut areas are problematic. Easy to bend a rotor and blade changes expensive. Tall grass is difficult to cut with a flail and the PTO HP of a LX2610 is less than 20. Tall grass much more difficult cutting vs weeds. Even a light duty rotary cutter will chop a cement block with minor issues.
I tried 3 small tractors with near 20 PTO HP on a 50 inch Ford 917 flail in excellent condition. None had the power to mow 12 inch grass. The PTO HP of a HST tractor is substantially less than the engine HP.
Sounds more and more you need an L tractor in 30 HP range.
/ B2601 vs. LX2610 #22
Bingo.
SDT
/ B2601 vs. LX2610 #23
The Woodmaxx 60" flail works well behind my L2501 and cuts down tall grass and weeds SO much better than the 5' rotary cutter I was using before. See for yourself, Messicks recently did a video comparing a zero turn, rotary cutter, and flail mower behind a LX2610 (or B2650) cutting tall grass. MOWER COMPETITION - Flail VS. Rotary Cutter VS. Zero Turn - YouTube
I'm sure the Woodmaxx is a non-commercial unit but it seems very well built running 3 self adjusting drive belts and while it weighs 650# the fact it's more compact allows the small L to handle it with ease. Flail Mowers for Sale | FM-62 Flail Mower | Flail Mower 62" | Finish mower - WoodMaxx
My previous B2650 struggled a little with the weight and length of the 60" medium duty rotary cutter, a light duty 60" or 48-54" medium duty would have been better, but I believe it would handle the 60" Woodmaxx flail I have ok.
/ B2601 vs. LX2610 #24
Old thread but still relevant. Regarding the comment about the mower competition by Messicks. Neil also had a video posted about this flail mower (has since been taken down) where a hidden chunk of wood was hit, wedged in and damaged the mower.
36 BLADE AC CENTER FOLD DISC HARROW (A63291)
36 BLADE AC CENTER...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRACTOR (A59911)
2014 FREIGHTLINER...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2013 EZ-GO GAS GOLF CART (A64280)
2013 EZ-GO GAS...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A61572)
2023 New Holland...
