Comparison B2601 vs. LX2610
/ B2601 vs. LX2610 #21
Non-commercial flails used on rough cut areas are problematic. Easy to bend a rotor and blade changes expensive. Tall grass is difficult to cut with a flail and the PTO HP of a LX2610 is less than 20. Tall grass much more difficult cutting vs weeds. Even a light duty rotary cutter will chop a cement block with minor issues.
I tried 3 small tractors with near 20 PTO HP on a 50 inch Ford 917 flail in excellent condition. None had the power to mow 12 inch grass. The PTO HP of a HST tractor is substantially less than the engine HP.
Sounds more and more you need an L tractor in 30 HP range.
/ B2601 vs. LX2610 #22
Bingo.
SDT
/ B2601 vs. LX2610 #23
The Woodmaxx 60" flail works well behind my L2501 and cuts down tall grass and weeds SO much better than the 5' rotary cutter I was using before. See for yourself, Messicks recently did a video comparing a zero turn, rotary cutter, and flail mower behind a LX2610 (or B2650) cutting tall grass. MOWER COMPETITION - Flail VS. Rotary Cutter VS. Zero Turn - YouTube
I'm sure the Woodmaxx is a non-commercial unit but it seems very well built running 3 self adjusting drive belts and while it weighs 650# the fact it's more compact allows the small L to handle it with ease. Flail Mowers for Sale | FM-62 Flail Mower | Flail Mower 62" | Finish mower - WoodMaxx
My previous B2650 struggled a little with the weight and length of the 60" medium duty rotary cutter, a light duty 60" or 48-54" medium duty would have been better, but I believe it would handle the 60" Woodmaxx flail I have ok.
/ B2601 vs. LX2610 #24
Old thread but still relevant. Regarding the comment about the mower competition by Messicks. Neil also had a video posted about this flail mower (has since been taken down) where a hidden chunk of wood was hit, wedged in and damaged the mower.
2013 INTERNATIONAL DURASTAR 4400 FORESTRY BKT TRK (A63276)
2013 INTERNATIONAL...
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
NEW Wolverine 66" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 66"...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
26 Gallon Dewalt Air Compressor (A65579)
26 Gallon Dewalt...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
