B26 Repairs
/ B26 Repairs #61
Sounds like the loader valve is not holding in the float detent. Attached is a schematic for the L39 in the float position. I do not know if the B26 is the same. The L39 has hydraulic bucket leveling that can be turned on/off with a lever on the loader control. In the float position the boom cylinder ports are both routed to tank so there should be no hydraulic pressure. I have trouble with mine staying in the float detent. I have taken the detent apart and cleaned it, but it still tends to pop out after a while so whenever I use the float, I hold the lever down to make sure it stays there.
  • L39 Float.pdf
4'x6' Stack of Sheet Metal (A60463)
4'x6' Stack of...
PORTA COOL 2000 PORTABLE EVAPORATIVE COOLER (A59823)
PORTA COOL 2000...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61568)
2016 Volvo VNL T/A...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2025 Miva VA13 (A60463)
2025 Miva VA13...
(20) 2.5cm X2M Ratchet Straps (A60463)
(20) 2.5cm X2M...
