B26 Repairs
/ B26 Repairs #61
Sounds like the loader valve is not holding in the float detent. Attached is a schematic for the L39 in the float position. I do not know if the B26 is the same. The L39 has hydraulic bucket leveling that can be turned on/off with a lever on the loader control. In the float position the boom cylinder ports are both routed to tank so there should be no hydraulic pressure. I have trouble with mine staying in the float detent. I have taken the detent apart and cleaned it, but it still tends to pop out after a while so whenever I use the float, I hold the lever down to make sure it stays there.
  • L39 Float.pdf
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
Godwin CD150M Dri-Prime Towable Trash Pump (A61567)
Godwin CD150M...
RIG MATS (A60736)
RIG MATS (A60736)
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
