B26 Repairs
/ B26 Repairs #21
Sam,
I've been following your posts since you bought your new B26, and was surprised at how many little issues you were having.
I seriously considered the B26, but ultimately decided against it for the sole reason that I live at 8500' above sea level, and believed that the 26hp engine might be a little under-powered for my needs. I ended up with a B3030, which is approx 500lbs lighter in TLB form, and has the extra hp and engine displacement.
I have worked my machine fairly hard, have had the backhoe on and off countless times, have worked the hoe rather hard trying to pick through decomposing granite ledge, and have yet to experience any hydraulic leaks, weakening hydraulics, or loosening of any of the backhoe mounts or pivot points. I'm actually a little surprised by this because of the difficult digging that I have encountered (I had a chance to dig a long drainage ditch for someone down at 5500' on the plains, and it was like digging through butter in comparison).
My machine is now at 250 hours. About the only loosening pivots are on the FEL bucket, which has also been worked hard digging into decomposing granite.
Since the B26 hoe is rated at higher capacities all around compared to the BH75 hoe, maybe that has something to do with it. I believe the B26 has a higher capacity hydraulic pump, which may also have something to do with your issues.
However, I am surprised that you have had as many issues working a commercial unit in residential applications, where I've not had any issues with my homeowner unit working in tough conditions and while doing work for others in the neighborhood. This is something I have had concerns with, realizing that a homeowner unit will most likely not be able to take the abuses that a commercial unit should be able to take.
Hope you're able to get the issues worked out. As tough as my lighter duty homeowner unit has been, I'd expect your heavier duty commercial unit to be even tougher and more trouble free.
/ B26 Repairs
Sam,
I agree, our B26 should be more trouble free but I know our land is mostly rock and that has clearly been tough on the tractor. We have had two hose failures and this loss of power. I have also worked it very hard; I don't run the RPMs up high unless the additional strength is required. Also I would never consider our home/road build a residential application. When you dig hundreds of trees and their root systems along with all the large stones that accompany, something is bound to fail. I will keep you posted on the outcome of my problem.
/ B26 Repairs
A week has gone by and David Dearmond from Kubota has not returned my calls or showed up at the dealer to check out our B26. The Dealer called me on Tuesday the 12th and said they found a pinched hose on the out riggers and wanted to know if I was going to pick it up. I asked if the stabilizers will now lift the tractor at a 1000 RPMs and he said no. I opted to wait to get the proper repairs. I think it is possible the service department asked the Kubota service rep to hold off a week while they attempt to remedy the problem. I sure hope we get this problem corrected. I will not be told that the tractor can only lift at idle when new. I found Kubota's claim is still on their web site at http://www.kubota.com/f/products/b26/pdf/b26_backhoe.pdf and says "Stabilizer Lifting Capacity We've increased the stabilizer lift capacity to give you greater control on any terrain. The improved capacity results in better balance, which reduces unwanted settling. It also means more strength-rear tire lift is possible even while the tractor is idling."
I will hold them to their word!
/ B26 Repairs #24
Posting the ad is GREAT!!!! I am really interested to see how this plays out. Now I want to see if the L48s I have will do that. I belive they do. I have 1 with 168 hours, the other at 1,589 hrs.
Good luck Sam.
/ B26 Repairs
Kubota's service representative David Dearmond never showed or called. I called Perrin & Gray's service department. They told me our B26 lifts at idle. I am confused because when I called earlier in the week they said they replaced a pinched hose but it was lifting above a 1000 RPMs. Anyway I tested in their shop and it worked fine. I would sure like to know what happened to David Dearmond. And am I to believe it was only a pinched hose on the out riggers? I guess I find it hard to believe our tractor has been in the shop twice for over three weeks because of a pinched hose. Don't get me wrong I am pleased they repaired it but somehow I feel that I wasn't afforded the truth on how we got to where we are now.
/ B26 Repairs #26
This has all been interesting. It certainly is possible one pinched hose caused your issues - flow is certainly affected by engine rpms on my machine, so I'd suspect yours would be similar. The higher rpms may have pushed the hydraulic fluid flow closer to its max, which allowed the outriggers to lift and overcome the obstruction of the pinched hose, whereas at idle, the pump just couldn't push the fluid past the pinch fast enought to lift the outriggers?
Your B26 has 2gpm more pump capacity than my B3030, and my BH75's outriggers can lift the back of the tractor, with loaded tires, to their full height at idle (1000 rpms), without any problem.
All that being said, I'm glad you have your machine back, and at 100%.
/ B26 Repairs
Thank You and All who have assisted.
Sincerely
Sam Walton
/ B26 Repairs
I got a call from the Kubota service representative David Dearmond today. I was a bit surprised to hear from him because he didn't return my many calls. He told me he had a good excuse, which was he had developed a staph infection on his foot. I told him the dealer had completed the repairs. He asked me if I wanted him to take care of the repair bill so I said yes. So the dealer will cut me a check after Kubota pays for the repairs. Not a bad deal, but I would have preferred the service to be completed in one trip and not over three weeks. Again I must say I am happy our B26 is repaired.
/ B26 Repairs #29
SamWalton: I'm also considering a 2013/14 B26 and will be working her hard moving rock and tree stumps. If you had it to do over, would you still have gone with your B26?
Do you think the "industrial" rating of the B26 is over-rated?
I've got a ton of narrow trails I'd love to be able to get my TLB back into to help clear out fallen trees and drag boulders back to the house to build a retaining wall, but hate to spend the cast for something that won't cut the mustard. Love an update on your B26.
/ B26 Repairs #30
I've got a B26 with about 11 hours on it. I've dug up 2 oak tree stumps both about a 10-12" trunk in dense clay soil. I had to dig completely around the stumps down to a depth of about 3 to 4 feet before the B26 had enough power to break the stump free.
The loader will lift a completely full bucket of broken up slab concrete. However, I tried to lift my 5th wheel RV so I could move it around the yard and NO GO. I even tried lifting it with the round transverse support bar closer to the cylinder attach points and NO GO. The cylinders for the boom appear small. I asked my salesman about installing larger cylinders and he said there is risk of cracking the engine block.
Back to the OP....my out riggers will lift the tractor at idle no problem. The cylinders on the outriggers are significantly larger than the boom cylinders on the front loader. Arrrggh!!!
/ B26 Repairs #31
Boom Cylinders are sized for the weight of the tractor. Typically will stall the bucket before rear lifts, though bucket curl might still lift a rear. Bigger Cylinders would be dangerous. Very old thread, wondering how the repair held up?
/ B26 Repairs #32
Sam,
You don't play around! The contact numbers that you received are excellent to have!!
The first thing I'd do is to accurately measure the Hydraulic System Pressure with a Calibrated Master Pressure Gage at the correct Idle RPM and adjust the Hydraulic System Pressure Relief Valve to 420.6 PSI.
I seriously believe that with the required System Pressure at Idle RPM all your flows will be where they belong. The reason I state that is that to achieve the advertised flows through Calibrated Orifices in GPM you need 420.6 PSI at Idle RPM. You DO NOT just raise the RPM!!! When you are running your Engine at any other speed above Idle RPM the Hydraulic System Pressure Relief Valve will maintain 420.6 PSI. I don't believe that the Hydraulic Flow of your Kubota Tractor is adjustable without changing the size of the Orifices.
As before, I don't have the Kubota B26 Manual but Hydraulics was one of my specialties of many and I've designed Hydraulic Systems, taught Hydraulics, and traveled Internationally as an Aviation Consultant throughout the Americas, Europe, Russia (Including throughout Siberia), Asia, and Africa. I was also an Independent FAA DME (Designated Mechanic Examiner) for both Airframe and Powerplant giving the A&P Oral and Practical Exams for many years before I retired.
Good luck to you,
Jim
Hi. Running a 2012 B26 and when trying to plough snow the bucket float starts working as it should, but shortly starts down pressure digging into the earth. This is all the while dtent still holding. Is their some adjustment to fine tune it ? Has done this since new and dealer just said " thats the way she goes with the B26" Thanks in advance.
/ B26 Repairs #33
The reason is the angle and forces on the loader arms while being pushed by the tractor and pressure of the snow passing back. Nothing wrong with the tractor.
/ B26 Repairs #34
+1 That is normal; both of my FEL's operate like that also. The float is mainly for levelling while operating in reverse. Not intended to replace a rear 3 pt blade, which can be set to float and not lift up like that when going forward.
/ B26 Repairs #35
That sounds unfortunate and bizzare. They should not call it float then. I have a 1974 JD with detent that does float for snow plowing so just figured Japaninese engineers 38 years later could do the same thing. I guess the solution is to curl the leading edge up slightly and just run on the bucket bottom, and let the front end lift. So much for steering. Good to know I'm in the same boat with a lot of others. Thanks.
/ B26 Repairs #36
Float just means that there is no hydraulic pressure resisting the up and down movement of the loader arms. The trick to get the bucket to ride level is to adjust it to find the sweet spot between digging in and riding up over what you are pushing. It is not an easy thing to do. It is all in the operator' s hands. The bucket is going to take the path of least resistance according to how it is adjusted. That is just how it is no matter what the color of the machine. Good luck.
/ B26 Repairs #37
With some practice, I think you'll get the hang of it. To fill the bucket with something you don't need to use the float; it works great just lowering the FEL to the ground and feathering the bucket to the right angle.
The issue with float is that as the bucket fills up, the added weight in the bucket makes sliding it forward more difficult. Eventually there's enough in the bucket that it doesn't want to slide at all and the loader arms simply swing down as the tires push the tractor forward. If you're using it for levelling, do what Toolguy says.
Good luck!
/ B26 Repairs #38
Thanks for the good wishes. If it worked according to your float description, I'd be happy. It does not have no hydraulic pressure. Thats is my entire problem. As I move forward the initial zero pressure changes to down pressure all on its own , hence the front wheels come off the ground, bucket leading edge digs in, and goodbye steering. A very poor snow plough compared to the old JD. All I am looking for is ( does the control have an adjustment ? Is it possible the factory set it wrong ?) Just seems crazy to me that sure a fine engineered machine has this very basic flaw.
/ B26 Repairs #39
I'll be contrarian to the other responses. Doesn't sound like it's working right to me. I use float on my BX25 for snow plowing all the time and as long as it's in the detent position, the bucket floats up and down with no hydraulic pressure up or down. Sounds like something is wrong with your valve. Might be worth opening it up and cleaning it out to make sure there's no microscopic foreign matter preventing it from going into full float mode. Maybe your stick is in float, but the valve is not fully closing off the pressure side. Have you spoken with a service tech at a Kubota dealer?
/ B26 Repairs #40
My B3030 does the same thing once a significant amount of material builds up in front of the bucket. If I stop going forward however, the front end comes back down. It would not do that if there was down pressure on the arms. Does your B26 come down if you stop going forward? Perhaps the extra weight of the backhoe makes the front end light enough that the lifting comes without much material in the bucket. Was your JD a heavier tractor than your Kubota. That could be the difference. If I am pushing something heavy and using float I have to pull the FEL lever out of float once I feel the front wheels start to lift. Otherwise, I loose traction and steering with the front wheels. It is a technique I had to learn from experience. Again, good luck.
John Deere 1025R (A64126)
John Deere 1025R...
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
Giyi Mini 4 In 1 Buucket (A64126)
Giyi Mini 4 In 1...
Bad Boy Rogue (A64127)
Deere 672GP (A64126)
