B26 Repairs
/ B26 Repairs #61
Sounds like the loader valve is not holding in the float detent. Attached is a schematic for the L39 in the float position. I do not know if the B26 is the same. The L39 has hydraulic bucket leveling that can be turned on/off with a lever on the loader control. In the float position the boom cylinder ports are both routed to tank so there should be no hydraulic pressure. I have trouble with mine staying in the float detent. I have taken the detent apart and cleaned it, but it still tends to pop out after a while so whenever I use the float, I hold the lever down to make sure it stays there.
  • L39 Float.pdf
167 (A52708)
167 (A52708)
LOAD OUT AND SHIPPING (A61165)
LOAD OUT AND...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
1010 (A61165)
1010 (A61165)
