B26 or B2920?
   / B26 or B2920? #11
RobbieBones said:
The 2920 is out of the question! The used 3130 (213 hrs for 23,000.00) has no hydraulic thumb and is not HST. But has more weight and a bigger stronger BH and FEL then the B26. (New 28700.00).QUOTE]
I disagree the BH90 backhoe is not stronger than the B26s BT820. The B26 has 4210 lbs. compared to the BH90s 3871 lbs. of Digging Force Using Bucket Cylinder but slightly less on the Dipper Stick Cylinder 2123 lbs. compared to the BH90s 2593 lbs. You are correct on the LA723 loader. Its breakout force at pivot pin is 2605 lbs. loader lift capacity to maximum height at pivot pin is 1870 lbs compared to the B26 TL500 loaders breakout force at pivot pin is 2344 lbs. loader lift capacity to maximum height at pivot pin is 1300 lbs.
JLG 1255 Telehandler (A56438)
JLG 1255...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
iDrive TDS-2010H...
43023 (A59228)
43023 (A59228)
