B2400 STARTER PROBLEM
/ B2400 STARTER PROBLEM #21
I have an m4900 and had the same problem. Checked everything and the ignition switch was the problem. Replaced it and all is well. Even called to get a starter rebuild before I checked all voltages and the rebuild center told me to check the switch as they had just had another person with the same problem and the swithch was defective. However it could be any of the components mentioned by others.
/ B2400 STARTER PROBLEM #22
Does anyone have the schematic for the solenoid circuit on a B2400?
/ B2400 STARTER PROBLEM #23
hey kubmech. got the starter relay as you recommended, but there are only #4 wires (#2 purples & black & red) on the new relay. the existing relay on my Kubota B21 is behind the instrument panel & has #7 wires (black, red w/ gray stripe, red w/ whit stripe, green w/ white stripe, white w/ blue stripe, white w/ green stripe, & brown). how do I wire the new relay in? thanks. jeff
2025 GPS Trailers (A56859)
2025 GPS Trailers...
CFG Inudustrial MH12RX (A60463)
CFG Inudustrial...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
