B2400 STARTER PROBLEM
/ B2400 STARTER PROBLEM #21
I have an m4900 and had the same problem. Checked everything and the ignition switch was the problem. Replaced it and all is well. Even called to get a starter rebuild before I checked all voltages and the rebuild center told me to check the switch as they had just had another person with the same problem and the swithch was defective. However it could be any of the components mentioned by others.
/ B2400 STARTER PROBLEM #22
Does anyone have the schematic for the solenoid circuit on a B2400?
/ B2400 STARTER PROBLEM #23
hey kubmech. got the starter relay as you recommended, but there are only #4 wires (#2 purples & black & red) on the new relay. the existing relay on my Kubota B21 is behind the instrument panel & has #7 wires (black, red w/ gray stripe, red w/ whit stripe, green w/ white stripe, white w/ blue stripe, white w/ green stripe, & brown). how do I wire the new relay in? thanks. jeff
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
Farmall Cub Tractor (A62613)
Farmall Cub...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
