Mowing B2400 HST won't move
   / B2400 HST won't move #1
jimsrx7
Natural Bridge, Va
154 Cub Lo Boy, B8200DT w/FEL, B2400HST
Hello,
I am in need of some help on this tractor - Kubota B2400 HST 1650 hours and 60" mower. When pushing the forward/reverse pedal, tractor jumps a little, but won't move but a couple feet if you are lucky. The hydraulic pump has been replaced, lines checked, etc. I am hoping it's not the transmission, in need of some help! Thanks!
   / B2400 HST won't move #2
How old is the hydro filter, is the fluid level ok?
DevilDog
DevilDog
Hello and thanks - I installed a new filter and it is full of fluid. Also, I have checked the screen filter in the line.
   / B2400 HST won't move #4
Does it have high / med / low range? Is it in one of those gears? have you tried the other ranges? Farmer had this happen to him... just checking the easy stuff first...
It has high/low. It won't move in either range.
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2449 (A60432)
2449 (A60432)
