B2320 transmission Problems
/ B2320 transmission Problems #1
waggy5
New York
Kubota M7040 & B2320
Hi, I have a 2011 kubota B2320 Hydrostatic with 4 wheel-drive. When the tractor is in 2wd and you press the forward pedal the tractor just barely moves forward like it is under strain, it just does not want to budge. However, if you press the reverse pedal the tractor seems to work fine in reverse and it has power to pull the tractor backwards the wheels will even spin and pull the tractor all over the place in reverse. Push the forward pedal and the tractor does not want to move. When I put the tractor in 4wd the front wheels will pull the tractor forward and will spin while the rear wheels do not spin. The front wheels do all of the work while the rear wheels do nothing or barely anything to help. If you put the tractor in 4wd and press down the reverse pedal front and rear wheels seem to work fine.
Anybody got an idea of what may be wrong with my little B2320?
thanks
/ B2320 transmission Problems #2
Start with something overly simple... Is the parking brake on?
/ B2320 transmission Problems #3
My daughter's BX had linkage problems (a bolt loosened up) in the hst pedal. Hers had similar symptoms but I don't know that 4wd /2 wd made a difference.
/ B2320 transmission Problems #5
Did you try it with the diff lock on? I know my 2620 will move around just fine with the parking brake on. Ask me how I know :duh:
Thanks for the replies. the parking brake is not on.
2012 FORD SERVICE TRUCK (INOPERABLE) (A65643)
2012 FORD SERVICE...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
16ft Equipment Trailer (A65579)
16ft Equipment...
2020 John Deere 7R 210 (A64126)
2020 John Deere 7R...
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
Hayrack Wagon (A66408)
