B21
daro
Alleghany County,NC
Thanks again for all of the advice.
Does anyone have any (+/-) feedback about the B21.
Though I have not seen this tractor or know the maint/track record it seems worth looking at.
I was just offered a B21 w/ RT, RMRM, RB, BB, & PHD for 5K. Any suggestions welcome and thanks in advance for your knowledge and time.
Daro
IS that like 5K as in $5000.00???
Must be an offer from a REALLY good friend, some one that has no idea the value of what they are selling or a total scam. Of course it may be a REALLY high hour beat up machine but that sounds like a real low price for a B21 and all those attachments.
I have heard the B21 is a darn good little machine for its size. I have a L35 and it amazes me what it can do, as long as you keep its size/weight class in perspective of course.
Hutch
I agree with Hutch. I briefly considered buying a new B21 in 1995, but money was short and I didn't really need the backhoe so I bought a B7100 instead, but if I'd had a little more money, I'd have bought he B21.:)
Price sounds too good to be true. Momma always told me there's no such thing as a free lunch.
/ B21
Thanks,
The flyer sent to me doesn't show a BH.
Was this std or optional?
Sill waiting to get the history on this tractor.
Thanks,
Daro
Daro, the B21 was a TLB (tractor/loader/backhoe) but of course the backhoe could be removed to use the tractor with other implements. While I can't say for sure, I don't think Kubota sold them without the backhoe.
Thats a good price even without the backhoe. As mentioned, I would be suspicious of that price.
I don't know about the B21, but I believe you can order a B26 w/o the backhoe. While I was researching the B26, I ran across issues with the B21 tranny. Mechanic at local bota dealer said they see "a lot" of B21 tranny overhauls.
I own a B21 and it is a great machine. They are popular in the rental business since the are built to the same level as an industrial tractor. I am sure the reason for transmission problems is the rough use in the rental business.
I have operated a lot of backhoes over the years and I can tell you the little B21 is a fine machine and compares with the best, but on a smaller scale.
I used mine to excavate a pad for a new home, a large workshop, a guest house, put in a septic system, water system bury my power lines, and dig a pond. I also run a 5' tiller. I use it like a fork lift with a set of forks. It is easy on fuel and has adequate power for everything. Actually I would like a bit more on the backhoe, but I tend to really work it like a big Cat, or try to. I put about 300 hours on it last year.
The fact that it does not have a back hoe, suggests that it was swapped off and sold with the 3 point hitch. The backhoe connections should still be in place since they are built into the frame. I would venture to say it could be added.
They usually hold value well.
Curt in Central Oregon
/ B21
I read a couple of threads about a tranny rebuild. I could do it but dedicating the time would have to be justified and its a a lot of work I don't need at this moment. The B21 does appear to be a very stout tractor for its size and HP and is perfect for my needs.
Your feed back continues to help and is greatly appreciated. Thanks again.
Daro
Around here used B21's with low hours go for 18-20K with a backhoe. They do look like pretty stout machines! Most of the ones I've seen for sale around here are from dealerships that have had them in the rental fleet. I have a friend who has had one for years, and he has done a remarkable job on his property with it. Of course, he is the kind of guy that does a remarkable job restoring antique cars too. :)
Of course, $5K US is ridiculously low, unless it is upside down in a ditch
somewhere.
The B21 is sold as a TL or TLB and it is still listed in the current price list.
The TL still gets the mainframe and is backhoe-ready.
I have been putting some hours on my B21 recently, mostly to see how
well the 4n1 FEL bkt works on such a small CUT. I also wanted to compare
the hoe to my CK30's hoe.
Photo shows the FEL at max lift. I could not move these rocks very
effectively withont the 4n1. I am selling the B21 this spring to make room
for the next project. It will be missed.
/ B21
Update,
Please accept my apologies as the info I received was incorrect at best. Though the brochure showed a B21 and assoc. implements this is not the tractor to be. As yo mammma says Ductape.
Hears the deal and I'm awaiting afew more details and photos.
B7300 CUT - probably a 99 or 00
1st owner 100hrs.
2nd owner 200hrs.
no known defects or issues with engine or tranny, good tread
includes:
factory bucket w/aftermarket tooth bar
48" rotary cutter (cond. unknown)
boxscraper (cond. unknown)
rear blade modified from a heavier/larger blade down to width of the tractor (cond. unknown)5
post hole digger Cond./auger size unkown
5K is a starting point, could poss. get in the upper3K to lower4K range
Its not the build of the B21 and I agree that was to good to be true. It still sounds as if I could do well with this tractor package for my needs.
I'll need a 3PH finish mower or a belly finish mower.
I can hire the back hoe work or investigate one for theB2300.
Any suggestions?
Any sound advice about this update is greatly appreciated.
Thanks again for your time.
Daro
2023 General XP 1000 Sport (A62679)
2023 General XP...
2012 Jeep Compass (A64194)
2012 Jeep Compass...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
2003 International 4300 Bucket Truck (A62613)
2003 International...
2017 EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
2017 EZ-GO SHUTTLE...
New/Unused Electric Winch (A65583)
New/Unused...
