B21 UDT leaking into crankcase...?
/ B21 UDT leaking into crankcase...? #1
kpmengr
Santa Maria, CA
Kubota B21, John Deere 325
Did a search and could not find a hit on this. Every time I run the tractor I loose hydro oil into the oil pan. My hydro dipstick is reading low and my engine oil dipstick is reading high. What seal should I check or is it even worth worrying about? This is my weekend toy and only use it a few hours per month so I can live with keeping an eye on it and draining/toping off as necessary. Tractor is new to me and had a hard life- but it was what I could afford. Thanks in advance!
/ B21 UDT leaking into crankcase...? #2
I would say it's the seal where your hyd pump hooks to the engine. If you plan to keep it for a while I would get it fixed. The UDT fluid isn't correct in the engine and will cost you big money in the long run.
/ B21 UDT leaking into crankcase...? #3
Sounds like the seal on the hydraulic pump that is mounted on the right side of the engine. It is driven all off of the same cam shaft that runs the fuel injection pump. It is all open into the crankcase.
Thanks guys. That sounds like it might not be too hard. Anyone replaced this seal before? How difficult a job is it?
/ B21 UDT leaking into crankcase...? #5
Doesnt appear to be too difficult from looking at my machine and the manual. Just be clean and careful on the assembly and you might want to do all the seals and bearings/bushings while you are in there since if the bushings wear down this will cause the seal to leak.
Here are the bushings and the seal and quantities
060 K3511-36760 BUSH 2
060 K3511-36762 BUSH 2
065 K3511-36760 BUSH 2
065 K3511-36762 BUSH 2
070 31381-76390 SEAL OIL 1
And these orings
050 6C040-36340 RING DOUBLE 1
050 6C040-36342 RING DOUBLE 1
050 6C040-36344 RING DOUBLE 1
I have the parts manual for the tractor if you want to PM me - or I think Messicks has them on line too.
Carl
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2013 Volvo VN Semi (A64047)
2013 Volvo VN Semi...
Box of Rachet Straps (A62183)
Box of Rachet...
