B21 how to start?
   / B21 how to start? #1
BruceWard
Platinum Member
Central, AR
The battery is charged, the clutch is in, is in neutral, the forward / backward pedal is centered.
The engine does not turn over, just like if the clutch was not in.
What else needs to happen to get it to start?
I parked it with the stabilizers out on a slight slope. I wonder if that could be the problem?
   / B21 how to start? #2
My B8200 is pretty similar. My clutch safety switch was a little out of adjustment; sometimes it would turn over, sometimes not. A quick adjustment got it working right again.
I have never had to worry about the range lever in neutral or the position of the for/back pedal. It is always good to have it in neutral, but it does not matter on my tractor.
   / B21 how to start?
Ill check the clutch switch tomorrow. Any other ideas what the issue might be? Are there other safeties or is the clutch switch the only one?
   / B21 how to start? #4
The B21 has a neutral switch. If it's out of adjustment, the engine won't crank. Move the range lever a little to towards the high range and see if this helps.
   / B21 how to start? #5
The clutch also has a safety switch and you do need the neutral position, both safety switches are worth checking. Do you get the Glow plug indicator light when you turn the key towards the start position? I am wondering if it could be a fuse issue.
MarkV
   / B21 how to start? #6
I believe you mentioned every lever but the pto. It could be the pto switch. I don't have a B21 but I assume it has one as well. I agree with MarkV, do you get any indicator lights, do the headlights work. Maybe even a loose or slightly corroided battery terminal, flakey key switch?:confused:
Stabilizers down shouldn't matter.
   / B21 how to start? #8
glad it was an easy fix, I think everyone has done that one time or another. Now you know for next time
simonmeridew
2006 International 4400 LP Crew Cab Heavy Haul Truck Tractor (A49461)
2006 International...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
Hilti TE 2000-AVR Electric Jack Hammer (A49461)
Hilti TE 2000-AVR...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
