AZ ranch
/ AZ ranch #431
Here in PA there are a lot of crawl spaces. My neighbor has a slab poured under his house, it makes working on plumbing and electric etc. a lot easier he just rolls around on an old office chair. Also keeps the moisture and radon at bay not sure if that is a problem where you are.
/ AZ ranch
I'm thinking I'll probably do that, AFTER my CO.
/ AZ ranch #433
Be sure to remove all the construction debris now. I have a rental with a crawl space, every time I am under there, I drag out more junk left by the builders.
It would also be a good idea to level out the ground now, it is a pain to dig after consructed.
Dave
/ AZ ranch #434
Dave
/ AZ ranch
I was able to get waterproofing on 3 walls today. I still had daylight, but my muscles were screaming at me. Tight space, awkward angles, I pretty much hate doing it. :)
/ AZ ranch
My neighbor came over and dug a ditch for my foundation drain! We have great neighbors!!
/ AZ ranch
I'm trying as hard as I can to get this foundation back filled before the nasty weather sets in. It snowed and sleeted a few days ago but we have sunshine again, at least for awhile.
/ AZ ranch
Back at it this weekend. I had 12 yards of gravel delivered that I used for backfill. I have 12 more coming Monday morning. This will bring it up to ground level all the way around. The weather is great this weekend, with lows around 38 degrees , but with days warming up to around 75!
/ AZ ranch #439
They make all sorts of conveyors, in all shapes, sizes and configurations. We have a couple of rental stores around here you can rent them from.
The last one I used was about 16 long and ran off 110v. This one didn't have a loading hopper, but the do make them with one.
Here is a random pic from the web..
/ AZ ranch
They make all sorts of conveyors, in all shapes, sizes and configurations. We have a couple of rental stores around here you can rent them from. The last one I used was about 16 long and ran off 110v. This one didn't have a loading hopper, but the do make them with one. Here is a random pic from the web.. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343073"/>
I need to rent one of those to get that excess dirt out of the crawl space. That and a tiller to loosen it up and I'm in business. I can lower either one or both of them down inside with the Telehandler.
Thanks!
John Deere 5100E (A60462)
John Deere 5100E...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2017 Bobcat 418 (A60462)
2017 Bobcat 418...
INTERNATIONAL 454 TRACTOR (A62130)
INTERNATIONAL 454...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
