AZ ranch
/ AZ ranch #471
First log is good. :)
I have a question, why is is not necessary to dress the the bottom of the log resting on the sill? It seems like the log would be "fitted" to the sill surface by providing a flat face.
/ AZ ranch
First log is good. :) I have a question, why is is not necessary to dress the the bottom of the log resting on the sill? It seems like the log would be "fitted" to the sill surface by providing a flat face.
With this particular style of log building, one does not flatten or notch logs. When two logs have a common flat surface, it becomes a magnet for water, which eventually leads to rot. This style keeps all logs round, so the water runs down one, and then continues to run down the next, with no flat place to "wick it in". Now if you like square logs, or D logs, then that's fine for you. I don't want to start an argument here. I'm not even saying that one is "better" than the other. Just trying to explain why I chose to do it this way.
/ AZ ranch
I finished one section of the pony wall this morning and installed it after lunch.
/ AZ ranch
Finished a 2nd section this afternoon. I'll install it in the morning, and hopefully finish the last section.
/ AZ ranch
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=366228"/> Then they dug out an area on the other side of the pony wall for easy access to the plumbing area.
These two kids were such hard workers that they got me way ahead of schedule. I didn't anticipate building the pony wall for another month, at least, so I didn't have all the materials. I had to make a trip over to Kingman Home Depot to get the lumber yesterday afternoon.
/ AZ ranch #478
Thanks Bo. I figured there is a reason. I have no log preferences. :)
/ AZ ranch
I know M7 built an excellent log home using square ones. Just different strokes for different folks.
/ AZ ranch
Finished the pony wall. On my next trip I will begin the floor joists.
2019 BOBCAT MT55 WALK BEHIND SKID STEER (A59823)
2019 BOBCAT MT55...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
(INOP) 2020 KUBOTA M6S-111 TRACTOR (A59823)
(INOP) 2020 KUBOTA...
2461 (A58376)
2461 (A58376)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
