AZ ranch
   / AZ ranch #461
I have followed your project from the beginning and enjoyed it very much! It has been quite an odyssey. Good luck with progress this year!
   / AZ ranch
I had some helpers for the last couple days. A friend came over with two young boys (13). Man can they work. They had that fit cleared out of the basement/crawl space in no time! I would have been working on that for another month!!!
   / AZ ranch
Then they dug out an area on the other side of the pony wall for easy access to the plumbing area.
   / AZ ranch
Here I am dragging the first log over to the foundation.
   / AZ ranch
And here is the first log being lowered down. There are 13 pieces of rebar of varying lengths sticking up out of the foundation. It is quite a chore to get them all lined up as the log is slowly lowered.
   / AZ ranch
Success!!! The first log is now in place!
   / AZ ranch #467
But Bo, but Bo, that log is too long! :shocked: Congratulations! That moment has been a long time coming.
   / AZ ranch
I want the overdangle to be about 3 1/2 feet and that is almost 5 feet, so when I'm all done, I'll trim off a foot or so. :)
   / AZ ranch #469
For me, that task would be impossible! Good job.
MoKelly
   / AZ ranch #470
getting that first log down is quite an accomplishment given the bureaucratic obstruction/indifference to the permitting process. sometime you just have to grind them down. well done!
   / AZ ranch #471
First log is good. :)
I have a question, why is is not necessary to dress the the bottom of the log resting on the sill? It seems like the log would be "fitted" to the sill surface by providing a flat face.
   / AZ ranch
First log is good. :) I have a question, why is is not necessary to dress the the bottom of the log resting on the sill? It seems like the log would be "fitted" to the sill surface by providing a flat face.
With this particular style of log building, one does not flatten or notch logs. When two logs have a common flat surface, it becomes a magnet for water, which eventually leads to rot. This style keeps all logs round, so the water runs down one, and then continues to run down the next, with no flat place to "wick it in". Now if you like square logs, or D logs, then that's fine for you. I don't want to start an argument here. I'm not even saying that one is "better" than the other. Just trying to explain why I chose to do it this way.
   / AZ ranch
I finished one section of the pony wall this morning and installed it after lunch.
   / AZ ranch #474
Nice work Bo!
   / AZ ranch
Finished a 2nd section this afternoon. I'll install it in the morning, and hopefully finish the last section.
   / AZ ranch
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=366228"/> Then they dug out an area on the other side of the pony wall for easy access to the plumbing area.
These two kids were such hard workers that they got me way ahead of schedule. I didn't anticipate building the pony wall for another month, at least, so I didn't have all the materials. I had to make a trip over to Kingman Home Depot to get the lumber yesterday afternoon.
   / AZ ranch #478
Thanks Bo. I figured there is a reason. I have no log preferences. :)
   / AZ ranch
I know M7 built an excellent log home using square ones. Just different strokes for different folks.
   / AZ ranch
Finished the pony wall. On my next trip I will begin the floor joists.
PARTS ONLY - Has Title - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - Has...
2011 Ford Escape SUV (A59231)
2011 Ford Escape...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
