Axel Ratings
   / Axel Ratings #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
What is the front axel load rating for a 1720?
I've seen posted here that the 7308 loader settings are 870# for the TC30, 920# for the 1720,and 1020# for the 1920. However, I've not seen the load rating for the front axel.
I'm researching a FEL for my tractor. The Bush Hog is rated at 1150# at max height at the pivot pins. This is 230# more than the rating for the 7308. I don't want to damage my front end.
Any input would be much appreciated.
   / Axel Ratings #2
My ex-NH1920 manual had a loading specs chart.. showed what max loads were for front and rear... So check your manual.
Soundguy
   / Axel Ratings
Soundguy
Soundguy,
Thanks for the input...
I have an operator's manual but can't find any axel load specifications...
Perhaps I'm just overlooking it...
Would an IT manual suffice???
I can get one at my local tractor supply...
   / Axel Ratings #4
No.. the I&T is a service manual.
In the owners manual.. check the back pages.. there should be specs / capacities , etc listed.
I don't have my 1920 manual anymore... it went with the tractor. My 7610s manual is laid out exactly the asmy 1920 manual was.. I could give you those axle rating specs (wink).. but I think they'd be a bit much for your 1720.
Soundguy
   / Axel Ratings
Soundguy
You think that 7610 is a bit heavier than that 1720???LOL
My dad's got an AC 8050...
I don't have a clue on how much it is but I'm sure it's astronomical...
   / Axel Ratings #6
Make sure that the 7308 loader spec you are comparing to is at the pins as well - If I remember right NH usually rates them at mid bucket. You'll have a higher rating at the pin that mid bucket due to the cantilever moment.
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
2012 Ford F-550 Bucket Truck (A49461)
2012 Ford F-550...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
