Axel Ratings
   / Axel Ratings #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
What is the front axel load rating for a 1720?
I've seen posted here that the 7308 loader settings are 870# for the TC30, 920# for the 1720,and 1020# for the 1920. However, I've not seen the load rating for the front axel.
I'm researching a FEL for my tractor. The Bush Hog is rated at 1150# at max height at the pivot pins. This is 230# more than the rating for the 7308. I don't want to damage my front end.
Any input would be much appreciated.
   / Axel Ratings #2
My ex-NH1920 manual had a loading specs chart.. showed what max loads were for front and rear... So check your manual.
Soundguy
   / Axel Ratings
Soundguy
Soundguy,
Thanks for the input...
I have an operator's manual but can't find any axel load specifications...
Perhaps I'm just overlooking it...
Would an IT manual suffice???
I can get one at my local tractor supply...
   / Axel Ratings #4
No.. the I&T is a service manual.
In the owners manual.. check the back pages.. there should be specs / capacities , etc listed.
I don't have my 1920 manual anymore... it went with the tractor. My 7610s manual is laid out exactly the asmy 1920 manual was.. I could give you those axle rating specs (wink).. but I think they'd be a bit much for your 1720.
Soundguy
   / Axel Ratings
Soundguy
You think that 7610 is a bit heavier than that 1720???LOL
My dad's got an AC 8050...
I don't have a clue on how much it is but I'm sure it's astronomical...
   / Axel Ratings #6
Make sure that the 7308 loader spec you are comparing to is at the pins as well - If I remember right NH usually rates them at mid bucket. You'll have a higher rating at the pin that mid bucket due to the cantilever moment.
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
Hilti TE 2000-AVR Electric Jack Hammer (A49461)
Hilti TE 2000-AVR...
TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
TRAIL MASTER...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
