Axel Ratings
   / Axel Ratings #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
What is the front axel load rating for a 1720?
I've seen posted here that the 7308 loader settings are 870# for the TC30, 920# for the 1720,and 1020# for the 1920. However, I've not seen the load rating for the front axel.
I'm researching a FEL for my tractor. The Bush Hog is rated at 1150# at max height at the pivot pins. This is 230# more than the rating for the 7308. I don't want to damage my front end.
Any input would be much appreciated.
   / Axel Ratings #2
My ex-NH1920 manual had a loading specs chart.. showed what max loads were for front and rear... So check your manual.
Soundguy
   / Axel Ratings
Soundguy
Soundguy,
Thanks for the input...
I have an operator's manual but can't find any axel load specifications...
Perhaps I'm just overlooking it...
Would an IT manual suffice???
I can get one at my local tractor supply...
   / Axel Ratings #4
No.. the I&T is a service manual.
In the owners manual.. check the back pages.. there should be specs / capacities , etc listed.
I don't have my 1920 manual anymore... it went with the tractor. My 7610s manual is laid out exactly the asmy 1920 manual was.. I could give you those axle rating specs (wink).. but I think they'd be a bit much for your 1720.
Soundguy
   / Axel Ratings
Soundguy
You think that 7610 is a bit heavier than that 1720???LOL
My dad's got an AC 8050...
I don't have a clue on how much it is but I'm sure it's astronomical...
   / Axel Ratings #6
Make sure that the 7308 loader spec you are comparing to is at the pins as well - If I remember right NH usually rates them at mid bucket. You'll have a higher rating at the pin that mid bucket due to the cantilever moment.
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
